eric1514
Aug 16, 2021Explorer
dougrainer wrote:eric1514 wrote:trailrider wrote:Yes it does, Thanks.
It looks similar to a system Newmar made for their motorhomes.
While it looks similiar it is NOT a Newmar style. The system is currently a LCI(Lippert) supplied system. BTW, Newmar slide systems except for the HWH they use is Patented by Newmar, so not other OEM will be using that system. If you are looking for the Motor/actuator, this link will direct you to just one of your style. Doug
https://store.lci1.com/slide-out-room-actuator-with-18-to-1-venture-motor-various-sizes-room-actr-18-1-vntr-mtr-assy.html
Thanks, Doug
The system is working well. I just wanted to learn about how it works. I see that actuator running parallel to those tracks.
For instance, at the end of the slide’s travel something makes a rapid thunk, thunk, thunk. I try to limit it to one or two but maybe it’s just a normal sound it makes, like a clutch.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
