rgatijnet1
Mar 13, 2017Explorer III
When you checked the transmission fluid was it with the coach sitting level, with the engine running, in PARK? This is to be done ONLY after the transmission is warmed up and has been shifted through all of the gears and has been left to rest for a minute or so with the engine running in PARK. Make sure that you set the foot brake before you go out to check.
38,783 PostsLatest Activity: Sep 23, 2026
