1957Hedgehog
Mar 13, 2017Explorer
rgatijnet1 wrote:
When you checked the transmission fluid was it with the coach sitting level, with the engine running, in PARK? This is to be done ONLY after the transmission is warmed up and has been shifted through all of the gears and has been left to rest for a minute or so with the engine running in PARK. Make sure that you set the foot brake before you go out to check.
Yes, sir, did exactly that in a rest area enroute home. Leak was so small while camping was hard to tell if it was a new or old spot. At rest area noticed fresh spot, cranked it back up, ran it through the gears (had to do this for a former toad), left it running and warm, checked fluids. Dip stick good. Now spot is bigger in my driveway.
38,783 PostsLatest Activity: Sep 23, 2026
