1957Hedgehog
Mar 13, 2017Explorer
rgatijnet1 wrote:
In that area the transmission can leak around the small red filter, where the oil cooling lines come out on the passenger side, as well as at the lower pan gasket.
You may have to get underneath and clean everything to find the exact location of the leak.
As mentioned, I would try tightening the pan bolts an extra 1/2 turn. You do not want to over-tighten them which may distort the pan and make it leak more.
Yes, sir, thank you. I'll check that area as well. From what I saw, at least 1 of the pan bolts had a drop on the head. And there was a drop at the bottom of the pan near the drain bolt. I do have a torque wrench so I'll check the Allison manual first before tightening.
38,783 PostsLatest Activity: Sep 23, 2026
