- PaleoExplorerIt seems it is under the kitchen cupboard, I have no idea how u could actually get it out without doing some massive mods, I was hoping I was missing something but it seems its just poorly designed.
- WyoTravelerExplorerOn some RVs it means tearing out panels. Mine was under the kitchen cupboard flooring. I had to take out the entire cupboard floor, reframe and modify so in the future I would have easy access. Quite a project but much better access. Plus a sturdier floor now in the cupboard.
- Old-BiscuitExplorer IIIDrivers side.........just forward of compartment that is in front of rear tires is the furnace intake/exhaust ports.
Furnace should be inside that 'fixed compartment' that ports are installed in. - sch911ExplorerThe flue and combustion air ports are on the outside of the rig. The furnace will be inside the rig right behind those. The blower is serviced from inside of the rig. You may have to remove a panel, or door, or drawer to gain access to it.
- rvtenExplorerGas furnace door outside. Look for two chrome ports. That is the furnace.
38,778 PostsLatest Activity: Jun 10, 2026
