trashguy's avatar
trashguy
Explorer II
Jan 07, 2018
Help me choose
Wife and I are about to pull the trigger on a new rig. The two we have narrowed down to are 2018 WINNEBAGO SUNSTAR LX 35F and 2018 Forest River Georgetown GT5 31L5. I do prefer the Winnebago. It's a little more price wise but seems better built and has a bath and a half. It does however have a residential fridge and for the next few years until I can retire, most of our trips are boondocking. I'm concerned that this may be a problem. I know solar can help but I'm guessing it isn't cheap to do. Realistically how long would we have to run the generator to make this work each day. I do have a small Yamaha 2000 inverter genny that I could use. It's quiet and uses next to no gas. Once I retire I see a lot more full hookup traveling so I'm torn.
  • wildtoad wrote:
    Why would you use the Yamaha when the MH has one already set to charge the batteries? I echo the Winnie selection if you’ve already narrowed it to these two.
    It's super quiet and burns like a gallon in 8hrs. I just figured since I already have it. I'm wondering how long does it take before the residential fridge kills the batteries. Would a few solar panels realistically be able to keep up. I do like the Winnie better but it's about 20k more and then I have to worry about battery life.
  • If yiou like the Winnie, get it. If you like that floorplan, have you looked at the Tiffin Allegro 36LA.
  • Why would you use the Yamaha when the MH has one already set to charge the batteries? I echo the Winnie selection if you’ve already narrowed it to these two.
  • Go with floorplan you like....Forest River is a crapshoot but Winnebago also could be..Winnebago has much more online resources and you can see every piece and system right online..so online support is top notch..As for residential fridge..2 hours in AM and 2 hours in early evening should cover all (you will have to run generator a bit more if furnace is running consistently)..my vote in the Winne.
