LaPlaya
Jun 23, 2013Explorer
dbbls wrote:
It sounds like you need to adjust the slide. Go to the Lippert home page and look up slides. It will show how to adjust them. Sounds like you need to raise yours up.
This will be good if I have the Lippert System. When I look under the slide from the outside, all I see is a fiberglass or plastic panel covering the whole bottom. I am not seeing any bars, rods, gears, wiring.. nothing, just a plain clean covering and no visible means of removing that panel.
38,707 PostsLatest Activity: Feb 28, 2025
