rgatijnet1
Jun 24, 2016Explorer III
I believe the noise you are hearing is the Auto Park Brake engaging or disengaging from the brake drum on the end of your transmission.
There is a way to manually disconnect the Auto Park Brake but once that is done, your coach will roll on a slopped surface unless you use wheel chocks. This can create a dangerous situation.
