MeanderMan
Sep 26, 2013Explorer
I had a capacitor go bad and short out, taking the circuit board with it. I replaced both the capacitors and the board, and my unit did the same as yours. I replaced the relays and it solved the problems. I'd try that first, they're only about $10 each if you order direct from Airexcel. They're easy to replace, located right above the circuit board on my model.
38,709 PostsLatest Activity: Mar 12, 2025
