luberhill
Jun 09, 2016Explorer
toedtoes wrote:
We would actually need to know the age of the motorhome (not the lady :) ).
If it's an older MH, then it is quite likely that the water heater is propane only.
I'm assuming "fried" is supposed to be "fridge". Most likely that is correct - it will run off propane or electric (when connected to shore power or generator) but will not run off electric when not on shore power or generator.
"newer tires" is not saying anything. Check the code on the tires to see the actual age.
Would have to know the age of the MH to be able to guess if $29K is reasonable or not.
where are the codes" on the tires,,,and how do you read them ?? Thx
