Bordercollie
Jun 10, 2016Explorer
If you have the time, look back at the "stickies" and many threads on this forum with advice on buying a used Class C. Date codes appear on the side walls of tires. Tires older than 5 years may be prone to coming apart or blowing regardless of tread depth or appearance. Brake fluid should be changed and brake system checked out. Engine cooling system, batteries and converter charger often need work . Leaks in roof or side walls may be very expensive to have fixed. These are basics. Get as smart as you can before buying a used rig and expect to spend some big bucks the first year, "depending".
