TDInewguy's avatar
TDInewguy
Help Needed: Rear axle is leaking lube - RV was sitting
Hello all!
I'm about to hit the road and head to Texas from the cold north (Minnesota) and in prepping the RV I noticed two puddles about 6-8" in diamater dripping off each rear brake drum.
I've got a 2002 Itasca Horizon with the 3126E CAT motor and Allison 3000. So it's a pusher with the big rear axle.
It was very very cold overnight a few days ago and I was heating the interior of the barn with a propane heater - to work, but it never got very "warm" inside, but there was a fair amount of humidity from the non vented combustion.
Anyhow - The coach has 110,000 miles and the rear has NEVER leaked anything - and while sitting there in the cold it puked quite a bit of lube out of each axle seal.
Here is one brake drum:
Here is the puddle of oil:
The other brake drum:
The other oil puddle:
Thoughts? What should I do?
