Baja_Man's avatar
Baja_Man
HELP!! No 12V or 110V power
Well, everything was going fine.....plugged into shore power at my home. All lights worked, AC ran, all good.
THEN......
I started generator while still plugged into shore power. AC, lights, and refer were all on. Then lights went out, AC stopped, and refer turned off... and almost all 12V items are dead...except for power slide and the power step.
What went wrong?
I'm not sure I should plug back into shore power???
I checked 12V fuses all appear good.
I checked AC breakers and they did not break. Turned them off and back on.
Is it the transfer switch? I can hear it running before I disconnected it.
Generator runs fine but will not power AC or anything
Where should I start?
I hope I did not fry my entire system:(
Thanks for the assistance.
  • Kill the generator. Plug in to shore power. Take your volt meter and start tracing power. Main fuses ar converter, fuse at house battery, fuse at transfer switch.
