Thunder_Mountai's avatar
Thunder_Mountai
Explorer II
Jul 04, 2023
Help with Power Gear leveling system
Need help with Power Gear leveling system on our 2016 Winnebago Journey. Haven’t called Lippert yet since it is a holiday weekend. Thought I would give you folks a shot at my problem first.
My problem is the front two jack will not deploy. This happened last year. But that time it was caused by low voltage due to aged out chassis and house batteries. Replaced them and everything was happy.
I have check the fluid level and It is good and my voltage is good. Any suggestions?
  • Are you trying in auto mode?
    Do the airbags deflate?
    Does the pump run but no jacks go down?
    Have you tried manual mode?
    I have had a few times in the past where coach was level enough that jacks would not move in auto mode.
