- https://store.lci1.com/control-asm-hyd-lv-for-3-valv-1010001002
This link is probably what your specific control box looks like. Doug - The last Poster has no clue. This is the link for the PG troubleshooting and lists each Touchpad with the correct control box. There IS a control box separate from the Touch pad. Usually on Gas chassis, the control box is mounted in the center area of the Motorhome on the outside between the exhaust on the roof of the floor. If Diesel, same, but on the roof of one of the storage compartments in the center of the Motorhome.
https://lci-support-doc.s3.amazonaws.com/manuals/leveling-and-stabilization/ccd_0002309.pdf - wa8yxmExplorer IIIThe control box is the pad with the buttons on it in your dash.
The Sensor box is a bit harder to find but generally let me draw you a mind picture.
Imagine taking two long strings. Tie one to the Right front and left rear jacks
Tie the other to the left front and right rear
They form a giant "X" marks the spot.
Now starting under the rig. Look above the "X" Not there (No surprise)
Open the compartment that's above the X.. Look there on the "Ceiling" FOUND IT. Well... I did on my rig.
but that's the sensors and "centering" controls (Adjustments)
The control box is the button pad. - Can you state the reason for locating the control box? The only time you need to find and mess with it is if it is faulty(replacement). Are you wanting to calibrate the level? If so, that is a function of the Keypad and not the control box. Doug
- gb76087ExplorerNot a Monaco, but my 2007 Fleetwood Terra has the control box mounted on the roof of the shelf above the propane tank. Passenger side, front.
38,782 PostsLatest Activity: Aug 11, 2021
