mailman-ret's avatar
mailman-ret
LIPPERT ELECTRONIC LEVELING SYSTEM
DW and I just took possession of our new Dutchman DENALI. It is equipped with a self leveling LIPPERT system. The information pertaining to this system was significantly vague other than it's control panel mounted description storage compartment location.
I have health problems and I am posting this to see if any other owners are aware of any problems have not yet been identified. This inquiry is an attempt to insure that we should know what we will need to do should this system malfunction during our future outings. When I attempt to check the net for anything that might be available on the LIPPERT site, I am stopped as I get to a location that asks for a model number, of which I am not able to locate.
As soon as possible we will get back with the dealership to see if anyone has any other information than that they provided during purchase and pick up. Thanks in advance to anyone who can shed any light on our concerns. The unit came with two crank handles that they couldn't locate a use for as all devices are electric including tongue jack.
  • Thanks to everyone's suggestions, I was able to locate the correct manual for our Ground Control TT Leveling System.
  • If your system is the level up hydraulic unit from lippert then yes it will. If your system is the all electric (as you said in your original post)ground control system then they do operate and are maintained quite differently.
  • I would like to thank everyone for responding to my information request. It appears that the manual that spud1957 listed will answer most any question that arise, thank you.
  • A phone call to lippert will walk you through any ? You have,
  • spud1957 wrote:
    We didn't get a manual with ours. Only a DVD.
    I downloaded the manual here.
    Level-up Manual
    Level up is the hydraulic system. Ground control the electric system from lippert.
  • Any advice on use will relate to what version of the lippert ground control system you have installed. That is where to start. If the jack tubes are round it is ground control 3..if they are square it is 2. Both have manuals on line.
