Majorpain's avatar
Majorpain
Electronic Leveling
I have a 34 foot class A RV with LCI electronic leveling. I am new to using a unit with levelers. When I use the auto level feature sometimes only the front jacks come down and not the rear jacks. When this happens it seems to be level from side to side. Can anyone tell me if this is normal?
Thanks in advance!
  • If your control panel looks like this:
    You can download a manual at:http://www.lci1.com/images/Flyers/Owners_Manuals/Leveling/om-electronic-leveling-web.pdf
    Page 10 of above referenced manual wrote:
    You will also note that it might not be safe and it is not recommended to end the leveling procedure with any wheels off the ground. I carry blocks to drive up on if this happens. Remember to put the same number of blocks under the nearest jack as used for the tire.
    I hope this helps you...
    Jim
  • The rear jacks do work on manual. I think I will try leveling on manual too so it doesn't lift so high. Thanks to all that replied!
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    Not normal. I have LCI jacks also, they should all deploy beginning with the front then the rear; after contact with the ground, they will begin front to rear leveling then side to side.
    Typically the jacks lift the coach too on 'Auto' for my liking so I use the system on 'Manual' and level it myself.
    Do the rears move down on 'Manual' mode?
  • ALL auto level systems, all jacks must hit the ground. Even LCI. So, NO, it is not normal. ALL jacks must hit the ground. Doug
  • If it's level, it's level :)
    Sounds to me like it's working just fine. When I use my auto-level function, I manually extend all 4 jacks just a bit more to reduce motion in the coach.
    Jim
