hotjag1's avatar
hotjag1
Explorer II
Mar 19, 2015
Help, no power to slideouts.
The last time that I used the slideouts, I had to flip the 12v disconnect rocker switch on the panel just inside the doorway to get them to work. I thought maybe I had bumped the switch prior to that and maybe it was in the disconnect position and had to be reset.
This time, I have flipped the disconnect switch numerous times and still have no power to the slides. I know that the switch is in the on position because everything else that is 12v works.
I have tested and verified 12v power at the fuse panel labeled slideouts.
Could there possibly be more than one fuse panel for the slides? Anyone else have this happen to them? All suggestions are welcome.
Thanks...Don
  • It sounds like your slide solenoid may not be working correctly. Not sure about your model, but on ours it is located in the rear-most compartment on the passenger side and is well labeled. The two large wires on it pass power to the electric slides. You can short those two wires in an emergency and I have also just whacked mine with the handle of a large screwdriver once the ignition is on while waiting on a new solenoid, but a replacement is in order.
    If you don't know about it, the Tiffin RV Network web site has a great forum (link on the left side of that page) which is a wonderful resource for Tiffin owners. It has no relationship with Tiffin Motorhomes but is ran by other Tiffin owners and has great members sharing info making everyone's life simpler.
  • My slides have a power lockout. After a wash job at a truck wash I couldn't close 'em. After a panicky brain #*%* moment, we found the right combo of flipping the switches to get them closed.
    It was there in the owners manual in geek speek.
    Good luck!
