j-d
May 13, 2017Explorer II
WILDEBILL308 wrote:
I would just replace the whole faucet assembly. Most of what they use are cheap plastic. Take the old one out and go to Home Depot and match the spacing.
Bill
That, or take the thing out and visit an Ace Hardware (or big box if you've found they have decent staff in Plumbing Dept) and perhaps they can dismantle it, and ID the part(s)you need. I dismantled the one in a rental RV we had in Alaska, took the pieces to the local True Value (Homer) and they sold me the piece I needed. And, rental company gladly reimbursed me. Better that than call out a mobile tech. Point is, it was in an RV but a part from residential repaired it.
We had Phoenix faucets. They're cheap RV/Trailer stuff, but had lasted 10 years hard use (nearly 4 years full time). After spending a lot of time trying to match the mounting form (spacing, number of holes) I just ordered this Phoenix
from Amazon
It put me in a high-arc faucet which I didn't have before, and I could remove/install with just my fingers. Fingers and some Plumber's Putty.
And no, couldn't see your pix. If you go to "Forum Tech Support" forum, there's a sticky "How to Post Photos." If they're on the WEB, you can copy the Image URL, then used "Advanced" instead of "Quick Reply." Select the icon that looks like a Post Card, Paste the URL, and select a Size less than 480. My faucet pic is 250.
38,782 PostsLatest Activity: Sep 10, 2026
