Daveinet
Sep 12, 2013Explorer
Most of the early to mid-2000s Rexhalls were lower than the typical standard. It was easily noticeable any time you would walk into an RV show.
One other thing you have to look at is if the drive is level leading into the garage. I went to back my coach into my Dad's barn. Door height was 10 feet, but the drive leading into the garage was up hill toward the door. When I backed in, the rear overhang of the coach was sticking up higher than the door and busted my rear AC unit shroud. Coach is 9'7" including ACs.
BTW: If the sat dish is a problem, it won't be after the first time you back it in.:)
38,778 PostsLatest Activity: Jun 06, 2026
