Spizzer
Sep 15, 2013Explorer
SCVJeff wrote:Spizzer wrote:i don't know the procedure, but I believe you can just dump the air and it will. I'll ask him since I won't be able to play with mine for another week.SCVJeff wrote:
That 11'6" Clearance Winnie posted is accurate. I dropped a tape on mine aired up and that is the min height I posted on the dash. That's with the Traveler installed and stowed.
I have a friend with an 06' 32T, and he drops his air to get into his carport. He set it works fine but you need to be careful and not forget the drill.
Cool, that is good info. Did your friend say how he does it? Do you have to hold the dump button down continuously any time it is running?
Jeff
I would appreciate that. One person told me that you hold the dump button and it dumps faster than it fills. So you have to hold it the whole time you are parking and then when you start it and back out. If there is a less mistake prone way, I would appreciate knowing it.
Jeff
38,778 PostsLatest Activity: Jun 06, 2026
