wa8yxm
Sep 17, 2018Explorer III
THe panel is not part of the Transmission. It may be a failed back light or it may be something worse.. If you are able to shift and drive they call it a PRiNDL
That stands for
Park, Reverse, Neutral, Drive, Low (often two lows) P R N D 2 1
You can count to 3 and drive it to the shop if it will let you.
Of course if there is no power to the Transmission.. It might not let you drive.
There is a test procedure described in the dash board owner's manual.
That stands for
38,769 PostsLatest Activity: Apr 03, 2026
