Smitty77
Oct 09, 2019Explorer
Alpines have I believe 36-40' Mid Entry Door coaches. I prefer Tag's for 40', but the Peak Chassis is known as one of the better handling Chassis on the market - so if not pulling a heavy trailer and or lots of CCC needed, would be trade off a bit less tight cornering maneuverability for better handling. Especially if looking for Mid Entry Doors. One other uniqueness to the Alpine Peak Chassis, is Hydraulic Over Air Brakes. And this ISL should be a Jake Compression. And Apline's usually have all axle Disc Brakes... (On Disc brakes. IMO, identical coaches with identical weights and going identical speeds - a Disc Brake (At least on the Steers.) will stop shorter in an emergency stop, then all axle Drums. At highway speeds, and based upon many variables, 10-20' shorter stopping would not surprise me.).
Here is one example of a 40' (Actually looks like well cared for (As much as pictures can tell...), and lots of storage, well appointed. :
https://www.rvt.com/Western-RV-Alpine-Coach-40-Mid-Door-Triple-Slide-2007-Little-Falls-MN-ID8794932-UX142448
On Air vs Jack Leveling. Pro's and Con's (As with all things in RV's:)!) Just a few comments, and for sure not a complete comparison: No need to put out pads or blocks with Air Leveling; No stuck in the mud Jack Feet with Air Leveling; Air Leveling can have less range, in difficult leveling contains (But, you can put blocks under tires.); Air Leveling can give you some rocking when walking and or in strong winds; And a final comment on this brief info - Some coaches had both Air Leveling and Jacks available... So more weight, but also more options...
Happy hunting,
Smitty
Happy hunting,
Smitty
38,774 PostsLatest Activity: Apr 26, 2026
