Argosy24
Aug 22, 2013Explorer
I had a shock bracket break and it punched a hole in the side of the gray tank. I used Eternabond to seal it 5 years ago and it's lasted.
Stress from the location is a good point. I think I would get a piece of relatively thin (~.060) aluminum or steel to help support the area. The ones I've seen are sitting on foam insulation so there is some flex anyway, just something to hold the edges of the split flat so they don't bend down and stress the Eternabond.
