lfeather
Aug 22, 2013Explorer
Road Runners wrote:
I would use plumbers epoxy. It comes as a small round putty like stick. You cut off what you want to use. Then, you work it with your fingers till it is a uniform color. Put that into the crack with overlap. It will harden and may be a permanent repair. I have repaired buckets, plastic fenders, potty water tanks, plastic rings that the toilet hold down bolts fasten too and lots of stuff. I have never had a problem with it once it hardens. You can buy it at home depot and lowes. For your appilication it is better than eternabond.
Do this and put EB tape on top of that and I would't be surprised if it lasts forever
