Geocritter
Aug 23, 2013Explorer
I'm done for the time being. Just as I figured, between the danged channel and working upside down in an enclosed space with some very sticky material, I screwed up the repair slightly. In other words it still leaks a tiny bit. However, at about a drop a minute or less, I've put a catch basin underneath and will simply dump the basin when needed. It is a temporary fix after all. When the weather cools down in October, I plan to replace the tank.
I expect replacing the tank will be a problem, I can no longer get an exact replacement and the front of the tank, where it protrudes from the storage space, as well as the associated inlet piping is covered with a few inches of polyurethane foam. Gee, that should be fun to deal with.
Oh well it's at least fixed well enough so that I can use it once again.
Steve
Steve
