Elvis_Presley2's avatar
May 06, 2017
HELP!!!! URGENT!!! water valves on minnie winnie
First time using it ever after winterizing. can't figure out directions to turn all these valves. Losing a lot of water trying to figure it out.
First is under the bed
2nd is under the bathroom sink
3rd is by the water heater.
https://photos.google.com/photo/AF1QipPW6KznA23U8flx96oeNIcW6EkLRmaAoN6sQVuM
https://photos.google.com/photo/AF1QipNA6bWLRxAgdl2sEvIQURjiaTA3UZbQ2NgnHhr5
https://photos.google.com/photo/AF1QipMTetgCZ4avT79NSe2PzEzalGDrbjUW7xLm896J
  • Try this
    https://goo.gl/photos/kQfTBwZqKy5ksyWk7
    https://goo.gl/photos/A1TtMVVrrCZkrkyE7
    https://goo.gl/photos/ce4ZkgYVpFv5YfV69
  • What Year? What Model number?
    Check out the Winnebago web site www.winnebagoind.com click Resorces you can find a lot of info on you rig such as plumbing and wiring diagrams owners manual. Dick
  • A guess since it's urgent:
    Low point drains are open ....close the valves under the sink (not the supply valves to the sink faucet, but the ones probably close to the floor.
    Fresh water tank drain is open....close this or these valves.
    We will talk about the water heater by-pass valves later.
  • picture links aren't working. Where are you loosing water to? inside? there's no place that water should be draining inside the unit. only drain should be the to the outside. water inside indicates a broken pipe someplace. Generally turn counter clockwise to open.
  • I might be able to help, but I get a 404 error message when I try to open the links to your pictures??
