just_justin,
Like ron.dittmer points out, and I will agree, if it has a propane generator, the deal would be OFF for me. No way! I want a generator that burns the same fuel as the chassis engine.
The other thing to realize, I believe the 7.3 was detuned for the van chassis over what was put in the pickup trucks. I believe that was due to cooling/radiator space or something like that.
Also, the E450 chassis, especially on larger Class C's, can push the chassis weight limites. The diesel weighs quite a bit more than the gasser, so that uses up some of your carrying capacity. However, seeing as that weight is on the front axle, the front axle usually is underloaded in most E-450 RV applications, so it's probably not a huge deal.
Lastly, is the diesel, in my opinion, gets you a better experience towing, but NOT more towing capacity. That's still limited by the chassis. And, it'll give you a better experience if you're running at higher altitudes due to the turbocharger, but again, how often will that apply to your use. And, of course, the availability of diesel is sometimes a bit harder to find at regular gas stations, but if you're not averse to refueling at truck stops, it shouldn't be a problem.
WAY back when, when we were doing our research, when we were looking at Class C's, I wanted a diesel. However, after LOTS of research on the subject, I quickly learned that the V10 is quite up to the task of moving around a Class C, and the initial cost, having a generator & main engine that uses the same fuel, ease of finding stations to refuel really allowed me to cross the diesel idea off my list. Heck, that V10 is used in Class A's with 10,000 pounds more GVWRs.
Oh....one more lastly :)  Have you contacted your bank about this? I thought I've read posts about banks not making loans on RV's over 10 years old. Even if they do make such loans, they are likely to only loan the amount of the LOWEST value shown in the books. They don't care about options, diesels, or anything else, so be ready to cough up a lot of your own money to make up the balance.  But, contact your bank and find out their policy. I believe people have said that their credit unions are generally easier to work with on purchases such as this, so keep that option in mind too! Oh, and I'd recommend keeping at least about $5,000 in reserve in a savings account should you have a major breakdown out on the road someplace.
It sounds like you're "sold" on it, though, so good luck with it, should you decide to buy it.  But in my opinion, it's WAY over priced. I'd offer him the lowest price in the NADA guideline, leave your number, and tell him to contact you when he's serious about selling it. Its half-past September and the camping season is rapidly approaching an end. He may be willing to really deal IF he doesn't want to keep it through the winter.
Good Luck,
~Rick
