Mile_High
Oct 09, 2016Explorer
DriverMan wrote:
My thanks to all of you for your comments.
It looks to me the roof problem with Winnebago is a serious one. Such a problem could literally destroy your motorhome. An that its most likely out of warranty by that time could be financially catastrophic, or am I overstating things?
You mentioned the seal, is this something you can reasonable check on your own? And if so is it something you can fix on your own?
How often should something like this be checked, every 5 years, 10 years, what? Can I assume this is all Winnebago's and not just the entry level Forza?
Is the a deal breaker? I can't think of many things worse than a faulty roof! I can understand slide problems etc, but a roof, Not Good!
I did a Google search for "trouble with Winnebago roofs" and was surprised to find very little on the subject! Has Winnebago commented on it anywhere and what their doing about it?
Winnebago has used that design forever, so in contrast to the ones that have trouble, there are tons of them out there that never do. Again, you only hear about the bad ones.
If the wind rips it off, its not the end of the motorhome, but it is expensive to fix, probably similar to replacing a rubber roof that has caught air underneath and billowed up and stretched.
I just checked mine (it is an easy check - you push on the edge of the fiberglass and if the seal splits open it needs recaulked). There were 2 places I pulled out the caulk and resealed it, mainly the black painted areas where the heat was highest in the sun.
Obviously from what I own I didn't think it was a deal breaker, and I still feel that way, it is just something to stay on top of like any other seal.
If you would like to see how the roof is actually installed - forward to minute 13:07 on this factory video and it will show you - pretty simple system. I think it is that interlock with the wall they don't want to give up:
Winnebago Tour
Also about minute 10:15 on this one below.
Winnebago Tour 2
