Diplomat_St_Poo's avatar
Nov 30, 2016
Hit my mirror. Need help removing mirror housing.
After 10 years I finally did it. Got to close to the MH garage post.
The mirror is screwed into the MH body from the mirror side. I'm having trouble figuring out how to remove the housing from the mirror.
The fitting closest to the MH appears to be one solid piece. Not sure how to remove the housing. I can't see any screws, it looks like one solid smooth piece. Any help would be appreciated.
  • Been there done that! Not too difficult:
    The mirror head will remove from the swing arm and the swing arm will remove from the base. It is also possible to remove the entire unit from where it seems to have broken loose:
    In the base are 4 plugs that cover screw heads. Pry off the plugs and undo the large screws--they need a large Phillips head screw driver
    BUT there are control wires running up the inside. In our rig there was a plug accessible from inside the rig but it was a real stretch!
    Once I got the screws out I reached in with a pair of side cutters and cut each wire. I helps to have someone else take the weight of the assembly. You can also remove the swing arm by backing out the large allen screws and lifting the arm up and out. IF the wires are long enough.
    IF the screws have torn out of the fibreglass and won't unscrew then I think cutting them off would be the only option, though you might be able to grip them with a pair of pliers on vicegrips to remove the screws.
    Looks like a Velvac mirror. You might want to contact them.
    Good Luck
    What I did was: remove the
  • You remove the ARM from the wall mount(bottom bolt). Then, the Black Plastic housing will pop off and expose the 4 mount screws. Doug
  • From the looks of it, I'd say a SawzAll would take care of it, or at least expose the insides....Dennis
  • I'm only guessing, but can you take the arm off, is there a nut on the bottom so you can take the arm off. then perhaps that will allow you to take the black housing off to expose mounting nuts underneath.
    Or does that black housing pop off, maybe with a screw driver, carefully prying it?
