j-d
Aug 30, 2014Explorer II
Ours was a few years older, but as I try to recall, the choke housing had a heat tube down to the intake manifold. Again recall, but the intake had an exhaust crossover to heat the carburetor base, and the that heat tube worked off of it. THEN the Choke Cover (the black Bakelite piece with the thermostatic coil in it) incorporated a thermostatic switch. It would not start to pull the choke off till the engine was well on its way to warmed up. A carb specialty shop sold me a "fast choke" which had no thermostatic switch. Choke heater came on as soon as the engine was running. Living in the Sunny South, I didn't need all that warm-up process. The Air Intake also had thermo stuff. A "Stove" over the passenger side exhaust manifold, with tubing to a "box" between radiator support and air filter. Replaced all that with 4-inch flexible dryer vent tubing.
38,782 PostsLatest Activity: Sep 02, 2026
