rgatijnet1
May 05, 2014Explorer III
Go to Home Depot and buy yourself a roll of cheap brown paper. Then use the paper to make a pattern to fit exactly where the carpet will go. Tape the pieces of paper together and you will have your pattern that you can use to cut the carpet. Mark the top of your paper pattern so that you can flip it and place it on top of the BACK of your new carpet. Use a marker to mark your cut lines and you are ready to cut.
If you pull off the old carpet, you will get an idea of how it is cut under the slides.
I would suggest that once the carpet is removed, that you put a couple of coats of urethane on the sub-floor to protect it from future leaks or spills as well as seal in any previous odors.
38,766 PostsLatest Activity: Jan 10, 2026
