fishingbob61's avatar
fishingbob61
Home made waste pump
Has anyone made a sewer waste pump from a house sink disposal from under the sink? I saw this someplace once and cant find it. Thank you in advance.
  • rjxj wrote:
    rv2go
    Slick idea just dont forget the dishwasher knock out :0. I have looked at the $200 12 volt pumps, thanks for posting your set up. I like it.
    Interesting website too. I put you in my favorites.
    Not my site. Just interesting ideas.
  • mtofell1 wrote:
    Just curious - how do you accomplish the required tight connection at the campground or dump station?
    Take a end cap for 3" pvc pipe, cut a hole in it so a hose connector will fit, place into the sewer donut then place into the CG sewer. If your sewer donut is larger than 3", get a 4" cap.
  • rv2go
  • Just curious - how do you accomplish the required tight connection at the campground or dump station?
  • I use one. I modified this one to my own ideas.
    RV Macerator Pump
    The gray flow thru. Pump the black as needed. 75 feet thru a 3/4 inch hose. Works like a charm. No worry of overheating the 12 volt pumps.
