Busskipper
Aug 28, 2013Explorer
MountainAir05 wrote:
Do not use drip system which is not safe for drinking water. Either use the clear plastic that they have on a roll or Plex depend on what they have. I would go along with the filter. Not that hard to Plex in a couple and the hold system is filtered.
Sort of thought that but just found the fittings in Pex. Watts PL-3003 Push Tee, 1/4-Inch OD LINK AND Watts PL-3011 Push Stop Valve, 1/4-Inch OD LINK
If I get enough fittings for two connections it should be able to take care of the drinking water also.
Johnny, I think I'll just find a 5 gallon square bottle and have it for all the time, when we run out just replace.
We have the same Manufacturer, hence he same filters, I used to use a third filter at the hose bib but CG water pressure has exploded two so I gave up.
Thanks to all for the HELP,
Busskipper
38,778 PostsLatest Activity: Jun 05, 2026
