Busskipper
Aug 28, 2013Explorer
Bumpyroad wrote:
the ice maker on my winnebago was filled from a separate under counter filter as was the tall drinking water faucet. a separate small piece of tubing ran across to the ice maker. it would be fairly easy to feed bottled water thru that?
bumpy
Bumpy,
Pretty sure that is the same as mine, Will go look at it and take pictures in the AM, then order the parts. Should be pretty easy to do the install, often when we are on the road and we have a number different water sources I am always just a little nervous as to the quality of the water in my tank.
If this works out it will just make everything a lot less of an issue.
Busskipper
38,778 PostsLatest Activity: Jun 05, 2026
