janstey58
Jun 12, 2017Explorer
Hot water pipes whine
Hi All, We have a 2015 Fleetwood Discovery with a really strange problem. Whenever we run hot water from any of the taps in the MH the water system makes a whining noise. It is loudest in the rear of the MH when taking a shower, in the rear bathroom. This is also where the water heater is located behind a wall in the rear.
Another fact, it doesn't matter if the hot water heater is in gas, electric or even "off" mode, the pipes still whine. We recently had the water heater replaced due to other issues and I thought this might fix it, but no. The check valve was also replaced on the water heater as well when the work was done.
This noise does not occur when running cold water, and yes the winter bypass valve is set correctly. Has anyone ever seen this? Looking for a fix! Thx, Jeff
