rv2go wrote:
It may be possible that you have 2 check valves.
When I heard that whine when using hot water, I replaced the check valve at the water heater.
Still had the whine.
Called Winnebago and was told there was a 2nd check valve and was told where it was located. Of course it was an arms length to reach. I got it out and removed the broke plunger and reinstalled it.
No more whine..
Could be a check valve on cold inlet fitting at WH Tank
But thought that was a 'Winnebago' thing ---for some reason they think it is necessary
It ain't :B
