Clay_L
Nov 14, 2013Explorer
I have reestablished the air pocket per Uncle Ts instructions (same as my manual says) several times over the years and the relief valve does not weep.
The manual says some weeping is normal but with the air pocket in place mine doesn't.
Regarding why the air doesn't leak out - that is puzzling - but the fact is it doesn't and the pocket does prevent weeping.
I believe the water is just above the relief valve when the water is hot and perhaps the water can push on and compress the air easier than weeping from the valve?
38,780 PostsLatest Activity: Jul 04, 2015
