I have an '07 Bounder. I had to cut an access hole in the closet wall, then cut the floor out of the area under the linen drawers to get to the back side of my water heater.
I tell you this because I lost all pressure to the hot side of all fixtures. I'm actually a licensed plumber. I wasn't sure what/how the
by-pass valve was doing. But, I found the mixing valve at the wh to be stopped up. I took it out, replumbed the entire wh area with my own by-pass valve set up. I installed a garden hose fitting with a ball valve on it so I could back-flush the wh if I wanted to.
