casefarmri's avatar
casefarmri
Hot water tank bypass valves
Would like to know if anyone (07 Fleetwood Revolution LE) has some info on why this water heater has only one bypass valve. Winterizing after blowing out lines and draining with valve in bypass position?????, took 15-20 gal of anti freeze. Heard should only take 3-4 gallon. Is one bypass valve enough to block flow to water tank? One year newbie and trying to learn everything before cross country trip this summer.
Help Plz!
  • assuming the shut off valve is after the T bypass pipe and before inlet into water heater, and there is an antibackflow valve in the pipe from bypass to outlet it should work?
    bumpy
