rickvikki's avatar
rickvikki
Hot water tank on/off switch
Hello everyone: What should be a simple job is not :(
We just changed the on./off switch for propane hot water because it was no longer lighting up when in the on position, but the little red light above would still go out when propane ignited. Now the light on the switch glows in the on position and little red light above stays red and propane igniter is clicking to fire up but never does. Now this would be too much of a coincidence that propane will not ignite anymore for some other reason than changing the on/off switch. Any ideas as to what is going on?
We have a Tiffen Phaeton 2006 DP, 40ft.
Thanks, Rick
  • But the hot water was igniting this morning before replacing switch?
  • Almost everyone has the same switch.
    I doubt your problem is the switch, I'm check the control board.
