I am an 06 Alfa See Ya. It looks like my water heater is leaking from the bottom. The hoses look dry. Does it need to be replaced and if you have done this what did you replace it with?
Pull the tank out before you buy a new one. I had a major water leak and I bought a new one online before I removed the old one. When I removed the old one I couldn't see why it was leaking. I plugged the water lines and started the water pump. I had a hairline leak in the PVC type tubing. I already had the new tank so I installed it. Wasted money.
