revumpExplorerApr 20, 2014Hot Water TankI am an 06 Alfa See Ya. It looks like my water heater is leaking from the bottom. The hoses look dry. Does it need to be replaced and if you have done this what did you replace it with?
egh33ExplorerApr 21, 2014Make sure it's not that plastic drain plug. Mine leaks once in a while. Before you go to all the trouble of removing the tank.
Related ContentNo flow from hot water tank Nautilus P1 systemWater tank won't fillDraining hot water tankhot water tankHot water tank drain plug
