I am an 06 Alfa See Ya. It looks like my water heater is leaking from the bottom. The hoses look dry. Does it need to be replaced and if you have done this what did you replace it with?
look at the brand. If it is an Atwood, I believe all of their tanks are aluminum so it has not rusted out, as could happen with other brands. With Atwood models the leaks are most often at one of the connections. Obviously this is something that needs to be taken care of ASAP and any damage to the sub-floor needs to be repaired and dried out.
