ybconway wrote:
When we got here the meter was showing 12.5 Volts. This morning it is at 12.2.
Is this normal?
I didn't really want to run the generator just because of the noise but am I at the the downside limit?
Yes this is reasonably normal.
12.2 is not really the downside limit but not too early to do some recharging either. Your battery charge is maybe 50% depleted and you should do some charging today. Many run the generator near dinner to also use the microwave etc while they prepare food. Need a couple hours minimum so start the generator at least two hours before any quiet hours limit.
I assume your solar panel is less than 80 watts and will provide a maintenance charge in storage. Not going to charge much while in use. Certainly you can start thinking about expanding the solar charging to be 200 to 400+ watts.
Yes the generator makes noise. To get the most out of the run time you need to verify your converter is charging at 14.2+ volts. Many just trickle charge at 13.6 volts. This makes a huge difference to cut generator time from 10+ hours to be 2 to 4 hours. Check voltage after running 20 minutes. Also post the converter model number for best options.
