country_sunflow
Jun 07, 2013Explorer
House batteries
DH doesn't know why he needs to add water to our house batteries about once a month. Anyone know about these batteries. Also he is planning on putting in more acid. Would this help?
holidayal wrote:
Why aren't my new batteries charging
RayChez wrote:
I use wet cell batteries for the house part on my coach and they last around six years, so I can not complain. But once the batteries start using lots of distilled water there is a problem. One could be your batteries never have gotten equalized and the sulfate has built up so much that the plates are not exposed anymore to the acid, they are covered with sulfate. So you need to replace the batteries. Check the batteries with a hydrometer and check each cell. It will tell you if the batteries are bad and need to be replaced. I like to change all four at once and that is highly recommended by the manufacturer.
You might also check your inverter/charger to see if it is set for the right type of batteries you have on the coach. It gives a selection of three different types of batteries wet, gel or AGM.
New wet cell batteries should not use any water, but need constant check up at least once a month. I like to wash them to wash off any acid that might have vaporized and gotten on your posts. Keep them clean by washing and even the battery box will never corrode.
