Bumpyroad wrote:
My old 12v batteries had 220 amp hours each.
My current 4 golf cart 6v batteries have 110 amp hours each.
It seems two golf cart batteries equal one 12v 8D battery.
In all cases the following refers to the C/20hour rating, Some companies rate their batteries differently so as to inflate the capacity, Wal*mart for example uses the C/1amp which gives a smaller battery over 100 amp hours.. at 1 amp. Due to an effect I can never spell (Starts with P, can never even remember the whole name less I've seen it recently,, Purket or plunket or something like that)
Your GC-2 Six volt were 220 amp hours each, when you put batteries in series you add VOLTAGE, not amp hours.
Your 12 volt.. Well, note the C-20
Group 24, about 75 amp horus each
Group 27 Round 95
Group 29 105
Group 31 140
I know of no 12 volt that is 230 amp hours but 4D and 8D bracket it
Some Ive seen are in teh 500-1000 amp hour range but, not only did they use a fork lift to set one on the trailer I used to tow it to the Field Day site we used it at...... Another of the same make and model POWERED the fork lift they used.
So your Two Six volt are equal to an 8D is, essentially correct (They are within 10%)
HOWEVER.. Do you want to wrangle an 8D.. I have the strength to do it but that's about max when I'm feeling good.. Sixes are easy for me, and I'm not sure I could wrestle an 8D in and out of where they stuck the sixes on this rig... (In fact fairly sure I could not) also how much did that 8D cost compared to a pair of sixes?
That is why six volt pairs are so popular
