SkyCop4U's avatar
SkyCop4U
hOUSE wATER pUMP
I have a 2008 discovery. The RV has a new water pump, but the issue took place before the new pump was installed. the unit has 5 rocker switches that turn the pump ON or OFF. I am having a hard time getting it to turn on. Most of the time it gives me a "flash" of the ON indication and does not tuen on. It is so hard to get it ON that I have been leaving it on for a trip to make sure I can get it turned on.
Any thoughts on where I should look?
  • That sounds like a nightmare of wiring problem if you have 5 switches. I assume there is a switch at each place you can get water in your unit. I would call the manufacturer to see how all these switches operate. They may all be in parallel with the power source and pump or there is some sort of central electrical box that keeps track of how the switches are set.
