midasman's avatar
midasman
How can I charge chassis batteries off of coach charger
My chassis batteries do not charge except off the coach alternator. I have an '06 Holiday Ambassador 8.3 ISC. I made some jumpers with alligator clips to try when it is parked and plugged in but then I got cold feet. So my questions are:
1. Can I just hook up + to the + feed to the coach batteries and - to the - feed without any diodes or other hocus-pocus?
2. Might it affect charging rate and float to the chassis batteries (which normally float to essentially zero amps)?
  • larry cad wrote:
    Another suggestion is a Xantrex Echo Charge. I have one and it works perfectly.
    X2
    It allows charging but keeps them separate
  • RLS7201 wrote:
    Yes, you can hook your 2 battery banks together (+ to +) with alligator clips. I would suggest at least 8 gauge wire. Just remember to remove the jumper if you boon dock.
    As previously mentioned, the Ultra Trik-L-Start is a very good option.
    Install it and forget it.
    Richard
    The wire in most battery chargers themselves is close to 16 gauge!!! You wont be charging at a high enough rate to require 8 gauge wires,.
    Fuse the wire running from PLUS terminal to chassis PLUS terminal in case one of the alligators pops off a post
  • Another suggestion is a Xantrex Echo Charge. I have one and it works perfectly.
  • Yes, you can hook your 2 battery banks together (+ to +) with alligator clips. I would suggest at least 8 gauge wire. Just remember to remove the jumper if you boon dock.
    Richard
