Monaramblee
May 18, 2020Explorer
dougrainer wrote:
If you have a slide cover, it must be removed or flipped on top the roof to replace the seal. Our shop charges from 2.0 to 3.0 hours to do the Metal teeth seal. That includes removing or flipping the slide cover. If no slide cover, 2.0 hours. You really need strong fingers to get the teeth onto the slide track guide. It is just a matter of working the new slide seal in place a few inches at a time. You start at either the front or rear bottom sidewall and work it up and across and down. You must also make a slit at the 2 top corners to get the wipe seal to fit evenly. Doug
Slide topper disintegrated so that helps.
Thankyou for the tips
38,782 PostsLatest Activity: Sep 10, 2026
